dino
2 August 2022 11:27
41
I had the problem of the GPS not working, on xperia XA2 plus
GPSinfo not see satellites
I reinstalled android via EMMA
then reinstalled sailfishos
it’s work
dino
dino
5 August 2022 10:31
42
hello
after few days the phone see the satellites but does not lock them
sorry
dino
ric9k
5 August 2022 20:41
43
Maybe the same HW problem that affected some of us?
have you seen this thread?:
After some introduction and considerations, I’ll share here the way I renew XA2 GNSS signal path from the motherboard through the antenna to the mysterious top cap (part of the antenna?).
The GNSS term is used here, as it stands for Global Navigation Satellite System, including GPS(US), Galileo (EU), GLONASS (RU), BDS (CN)…
Hardware, why?
Because there are much differences reported between XA2 GNSS capabilities, I believe the Sony Xperia XA2 can have some Hardware problems reg…
dino
5 August 2022 21:35
44
hello
i’m not see this thread !
i try it
thanks !
dino
ric9k
6 August 2022 05:14
45
You can also read the mythic and huge GPS thread where people discuss the possible causes of XA2 GNSS issues.
You will also find there nekron’s supl patch.
REPRODUCIBILITY (% or how often): 100
BUILD ID: 3.3.0.16
HARDWARE (Jolla1, Tablet, XA2,…): XA2 Plus H4493
UI LANGUAGE: English (US)
Attempt to use GPS in any capacity
GPS actually works
Location stuck in last place it worked. No updates or newly installed apps
(Please ALWAYS attach relevant data such as logs, s…
