Dear Sailors,
I am starting to collect keyboard shortcuts for hardware keyboards, so one could use them on the fly.
- Ctrl + Home = Switch to home screen. Besides that, it puts the cursor at first position in editor.
1.1. Home = Switch to home screen. Besides that, it puts the cursor at first position in the line. - Ctrl + Alt + Delete = Kill system (my XA2 turns off in an instant)
- Ctrl + Esc = Wake up / turn off screen when locked
- Win + Esc = Lock phone
- Alt + Tab = Switch apps. Works with the Taskswitcher App from Storeman.
Is there a shortcut to wake up and open the lock screen, so I can directly input a passphrase?
I am still searching for a workaround for AlienDalvik to use the bluetooth keyboard in there. It seems to catch the Alt-key and Shift-key, but does not combine them to upper case.
Cheers,
dexic
