Hard freeze or crash of GUI
REPRODUCIBILITY: 20-50%
OS VERSION: 4.4.0.68
HARDWARE: Xperia 10 III
UI LANGUAGE: Swedish
REGRESSION: …compared to other devices.
This is one of those borderline bug reports. Not sure if it is the OS or the app(s), but it just doesn’t seem like it is reasonably only the app’s fault, therefore i’m putting it here.
None
  1. Launch @slava’s eminent Foil Auth (much more rare with other apps, but it has happened)
App launches
Hard freeze or sometimes the homescreen restarts after a while, taking all apps with it.
None.
Journal is not obviously of much use:
aug 06 14:20:18 Xperia10III invoker[6554]: WARNING: An inactive plugin is misbehaving - tried to show a window!
aug 06 14:20:18 Xperia10III invoker[6554]: WARNING: requestActivate() called for  QQuickView(0x1d503e40)  which has Qt::WindowDoesNotAcceptFocus set.
aug 06 14:20:18 Xperia10III lipstick[5832]: [W] unknown:0 - WindowPixmapItem does not have a source texture, cover will be dropped..
aug 06 14:20:19 Xperia10III [26400]: [W] unknown:0 - The Wayland connection broke. Did the Wayland compositor die?
aug 06 14:20:19 Xperia10III jolla-notes[28864]: [W] unknown:0 - The Wayland connection broke. Did the Wayland compositor die?
aug 06 14:20:19 Xperia10III [2653]: [W] unknown:0 - The Wayland connection broke. Did the Wayland compositor die?
aug 06 14:20:19 Xperia10III jolla-calendar[19081]: [W] unknown:0 - The Wayland connection broke. Did the Wayland compositor die?
aug 06 14:20:19 Xperia10III prestart[26067]: [W] unknown:0 - The Wayland connection broke. Did the Wayland compositor die?
aug 06 14:20:19 Xperia10III kernel: binder: undelivered TRANSACTION_COMPLETE
aug 06 14:20:19 Xperia10III kernel: binder: undelivered transaction 2461477, process died.
aug 06 14:20:19 Xperia10III kernel: binder: undelivered transaction 2461476, process died.
aug 06 14:20:19 Xperia10III kernel: binder: undelivered transaction 2461475, process died.
aug 06 14:20:19 Xperia10III lipstick[5832]: Wayland display got fatal error 32: Brutet rör
aug 06 14:20:19 Xperia10III lipstick[5832]: Additionally, errno was set to 32: Brutet rör
aug 06 14:20:19 Xperia10III lipstick[5832]: The display is now unusable, aborting.
aug 06 14:20:19 Xperia10III kernel: binder: 5795:5806 transaction failed 29189/-22, size 76-0 line 3099
aug 06 14:20:19 Xperia10III [10943]: [W] unknown:0 - The Wayland connection broke. Did the Wayland compositor die?
aug 06 14:20:19 Xperia10III [7166]: [W] unknown:0 - The Wayland connection broke. Did the Wayland compositor die?
aug 06 14:20:19 Xperia10III fingerterm[11000]: [W] unknown:0 - The Wayland connection broke. Did the Wayland compositor die?
aug 06 14:20:19 Xperia10III jolla-messages[7029]: [W] unknown:0 - The Wayland connection broke. Did the Wayland compositor die?
aug 06 14:20:19 Xperia10III kernel: Core dump to |/bin/false disabled
aug 06 14:20:19 Xperia10III invoker[6554]: WARNING: The Wayland connection broke. Did the Wayland compositor die?
aug 06 14:20:19 Xperia10III mce[1925]: modules/display.c: mdy_stm_set_compositor_availability_changed(): compositor availability change: pending
aug 06 14:20:19 Xperia10III sensorfwd[3322]: [SocketHandler]: Socket error:  QLocalSocket::PeerClosedError
aug 06 14:20:19 Xperia10III mce[1925]: modules/display.c: mdy_stm_step(): forced brightness sync to: 327
aug 06 14:20:19 Xperia10III sensorfwd[3322]: [SocketHandler]: Noticed lost session:  5
aug 06 14:20:19 Xperia10III mce[1925]: modules/display.c: mdy_stm_set_compositor_availability_changed(): compositor availability change: handled
aug 06 14:20:19 Xperia10III sensorfwd[3322]: virtual bool HybrisAdaptor::setInterval(unsigned int, int) setInterval not ok
aug 06 14:20:19 Xperia10III mce[1925]: modules/display.c: mdy_display_state_enter(): current display state = ON
aug 06 14:20:19 Xperia10III [12784]: [W] unknown:0 - The Wayland connection broke. Did the Wayland compositor die?
aug 06 14:20:19 Xperia10III art[18679]: [W] unknown:0 - The Wayland connection broke. Did the Wayland compositor die?
aug 06 14:20:19 Xperia10III sailfish-qml[19391]: [W] unknown:0 - The Wayland connection broke. Did the Wayland compositor die?
aug 06 14:20:19 Xperia10III voicecall-ui[6956]: [W] unknown:0 - The Wayland connection broke. Did the Wayland compositor die?
aug 06 14:20:19 Xperia10III [6970]: [W] unknown:0 - The Wayland connection broke. Did the Wayland compositor die?
aug 06 14:20:19 Xperia10III [7001]: [W] unknown:0 - The Wayland connection broke. Did the Wayland compositor die?
aug 06 14:20:19 Xperia10III [6598]: [W] unknown:0 - The Wayland connection broke. Did the Wayland compositor die?
aug 06 14:20:19 Xperia10III systemd[1]: Starting Controller for display.service...
aug 06 14:20:19 Xperia10III systemd[5648]: lipstick.service: Main process exited, code=killed, status=11/SEGV
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-silica-qt5[6600]: warning: terminating: booster:10943 invoker:23525 socket:12
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-silica-qt5[6600]: warning: Daemon: sending exit(1) to invoker(23525)
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-generic[5671]: warning: terminating: booster:11000 invoker:18518 socket:14
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-generic[5671]: warning: Daemon: sending exit(1) to invoker(18518)
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-generic[5671]: warning: sending SIGTERM to booster (pid=11000)
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-silica-qt5[6600]: warning: sending SIGTERM to booster (pid=10943)
aug 06 14:20:19 Xperia10III systemd[1]: selinux: Unknown class service
aug 06 14:20:19 Xperia10III systemd[1]: Started Controller for display.service.
aug 06 14:20:19 Xperia10III simkit[7143]: [W] unknown:0 - The Wayland connection broke. Did the Wayland compositor die?
aug 06 14:20:19 Xperia10III lipstick-security-ui[6573]: [W] unknown:0 - The Wayland connection broke. Did the Wayland compositor die?
aug 06 14:20:19 Xperia10III ofonod[3328]: Agent exited without calling Unregister
aug 06 14:20:19 Xperia10III [7193]: [W] unknown:0 - The Wayland connection broke. Did the Wayland compositor die?
aug 06 14:20:19 Xperia10III polkitd(authority=local)[3321]: Unregistered Authentication Agent for unix-session:1 (system bus name :1.103, object path /org/sailfishos/Lipstick/SecurityUi/PolkitAgent, locale sv_SE.utf8) (disconnected from b
aug 06 14:20:19 Xperia10III systemd[5648]: simkit-agent.service: Main process exited, code=exited, status=1/FAILURE
aug 06 14:20:19 Xperia10III systemd[5648]: simkit-agent.service: Failed with result 'exit-code'.
aug 06 14:20:19 Xperia10III lipstick[5832]: [nfc-client] ERROR: GDBus.Error:org.sailfishos.nfc.Error.Aborted: Object is gone
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-silica-qt5[6600]: warning: boosted process (pid=2363) signal(Aborted)
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-silica-qt5[6600]: warning: Daemon: sending exit(1) to invoker(4733)
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-silica-qt5[6600]: warning: terminating: booster:12784 invoker:2360 socket:13
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-silica-qt5[6600]: warning: Daemon: sending exit(1) to invoker(2360)
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-silica-qt5[6600]: warning: sending SIGTERM to booster (pid=12784)
aug 06 14:20:19 Xperia10III autologind[5612]: *** signal=17 pid=5612
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-silica-session[5612]: warning: Boosted process (pid=6573) exit(1)
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-silica-session[5612]: warning: Daemon: sending exit(1) to invoker(6603)
aug 06 14:20:19 Xperia10III invoker[6603]: warning: application (pid=-1) exit(1) signal(0)
aug 06 14:20:19 Xperia10III systemd[5648]: lipstick-security-ui.service: Main process exited, code=exited, status=1/FAILURE
aug 06 14:20:19 Xperia10III systemd[5648]: lipstick-security-ui.service: Failed with result 'exit-code'.
aug 06 14:20:19 Xperia10III bluetoothd[4253]: bluetoothd[4253]: Player unregistered: sender=:1.89 path=/_1_146
aug 06 14:20:19 Xperia10III bluetoothd[4253]: Player unregistered: sender=:1.89 path=/_1_146
aug 06 14:20:19 Xperia10III booster-generic[5671]: *** signal=17 pid=5671
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-generic[5671]: warning: terminating: booster:16533 invoker:19351 socket:15
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-generic[5671]: warning: Daemon: sending exit(1) to invoker(19351)
aug 06 14:20:19 Xperia10III invoker[7209]: [gbinder] WARNING: Unknown local object 0x79e800ad40 hwbinder
aug 06 14:20:19 Xperia10III invoker[7209]: [gbinder] WARNING: Unknown local object 0x79e800acc0 hwpuddlejumper
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-generic[5671]: warning: sending SIGTERM to booster (pid=16533)
aug 06 14:20:19 Xperia10III kernel: binder: 7193:7193 BC_CLEAR_DEATH_NOTIFICATION invalid ref 4
aug 06 14:20:19 Xperia10III kernel: binder: 7193:7193 BC_CLEAR_DEATH_NOTIFICATION invalid ref 5
aug 06 14:20:19 Xperia10III kernel: binder: 7193:7193 BC_CLEAR_DEATH_NOTIFICATION invalid ref 1
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-qt5[5670]: warning: terminating: booster:6574 invoker:6554 socket:15
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-qt5[5670]: warning: Daemon: sending exit(1) to invoker(6554)
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-qt5[5670]: warning: sending SIGTERM to booster (pid=6574)
aug 06 14:20:19 Xperia10III booster-qt5[5670]: *** signal=17 pid=5670
aug 06 14:20:19 Xperia10III kernel: rpmh_rsc_send_data: 42 callbacks suppressed
aug 06 14:20:19 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
aug 06 14:20:19 Xperia10III droid-hal-init: Sending signal 9 to service 'vendor.qti.hardware.display.composer' (pid 5795) process group... HYBRIS: killing PID instead of process group.
aug 06 14:20:19 Xperia10III droid-hal-init: Control message: Processed ctl.restart for 'vendor.qti.hardware.display.composer' from pid: 4757 (/usr/bin/setprop ctl.restart vendor.qti.hardware.display.composer)
aug 06 14:20:19 Xperia10III systemd[5648]: lipstick.service: Failed with result 'signal'.
aug 06 14:20:19 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_dsi_panel_notifier_cb: power down
aug 06 14:20:19 Xperia10III kernel: (NULL device *): deviceless supply vdd not found, using dummy regulator
aug 06 14:20:19 Xperia10III kernel: (NULL device *): deviceless supply avdd not found, using dummy regulator
aug 06 14:20:19 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_power: off: avdd:on, dvdd:on
aug 06 14:20:19 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_pinctrl_configure: SUSPEND
aug 06 14:20:19 Xperia10III kernel: binder: send failed reply for transaction 2461480 to 7335:7502
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-qt5[5670]: warning: Boosted process (pid=7193) exit(1)
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-qt5[5670]: warning: Daemon: sending exit(1) to invoker(7209)
aug 06 14:20:19 Xperia10III invoker[7209]: warning: application (pid=-1) exit(1) signal(0)
aug 06 14:20:19 Xperia10III systemd[5648]: apkd-bridge-user.service: Main process exited, code=exited, status=1/FAILURE
aug 06 14:20:19 Xperia10III systemd[5648]: apkd-bridge-user.service: Failed with result 'exit-code'.
aug 06 14:20:19 Xperia10III autologind[5612]: *** signal=17 pid=40
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-browser[6999]: warning: Boosted process (pid=199) exit(11)
aug 06 14:20:19 Xperia10III /usr/libexec/mapplauncherd/booster-browser[6999]: warning: Daemon: sending exit(11) to invoker(-1)
aug 06 14:20:19 Xperia10III invoker[26399]: warning: application (pid=-1) exit(11) signal(0)
Already here i think it is well beyond the root problem.
Then processes start being taken down and eventually restarted…
