GSF installment
Which app do I need for full Android usage on the Jolla C2, and where is it? Many Android apps claim that my phone doesn’t have Google Play Services, and when I with MicroG do self-check it also says Services Framework (GSF) is not installed…
I can’t find OpenG in Aurora, Fdroid, Storeman, Openrepo or Chum, what should I search for or can you post an url for this?
Don’t make new threads like the world revolves around you. Just look up the MicroG thread and follow the instructions. Ask there if you have issues.
Your answer was not helpful. But I have just found the MicroG services app on F-droid, and that solved this exact problem.
Which one?
https://search.f-droid.org/?q=MicroG&lang=en
Your thread was not helpful, so i just returned the favor.
