Grok AI not work. it tell “check that google play is enabled”
from Aurora Store
from Aurora Store
Did you install microG?
yes all parts but i dont know is all tabs in microG settings like allright. so i leave this testing someone else and use SFOS without Grok
I would consider non-working Grok as a feature, not as a bug.
yes i understand this but i know a lot of people use it and i think i’m not ”onlyone” and a lot of questions arriwed when all get new Jolla’s
use the app from this topic : How to modify Android app so it thinks it was installed from Google Play - #12 by Rikudou_Sennin
change grok’s installer to google play
( works for most apps that check where they were installed from )
