GPS issue on AppSupport
Hi everyone, I’m having trouble getting a GPS fix in Android navigation apps running inside AppSupport. Native Pure Maps + OSM Scout works fine, but I can’t add speed cameras or ZTLs (limited traffic zones). Because of this, I downloaded OsmAnd from F-Droid, but unfortunately it often freezes and doesn’t even start navigating. Other online navigation apps like Waze or Petal maps are even worse. Is this a settings issue or something inherent to Sailfish (I am using a Jolla phone 2026 running latest updates)? Thanks!
You’re not alone, GPS only partially works, aGPS can find my location but GPS alone won’t. GPSInfo (from the Jolla store so it should do what it says it does) tells me it sees dozens of satellites but never uses any of them, aGPS can lock in outside more or less accurately (more or less, the accuracy varies, and interestingly inside with almost a km accuracy which is a far cry from my Samsung’s 10-ish meters, a problem if I want to order a taxi from a large place like a mall or a hospital and don’t want to wait outside but I can’t find which exit I’m closest to on the map) but every Android app relying on it I tried has the same problem, it locks in after I restart the phone (restarting Network and Cellular network in Utilities doesn’t seem to be enough) but as soon as I start moving, it just won’t follow me and from there it won’t find my location again until the next reboot.
Thanks for the confirmation. I installed GPS Info too, with the same result. OsmAnd works sometimes and I manage to use it, but it’s Russian roulette. Pure Maps is the only viable solution, though it’s not always reliable; sometimes it loses the signal or fails to recalculate the route (in addition to the insufficient information mentioned above). For traveling, I always have to rely on an Android device, which is frustrating.
