OSVERSION: 5.2.0.17
HARDWARE: Jolla Phone (2026) - jp2601 - jp2601 - 1.0.0.17 - aarch64
REGRESSION: not specified
The phone’s GPS never works. Pure Maps (native) and Organic Maps (Android layer) — wait forever for a satellite position. Network-based positioning works, but only to a few km of accuracy.
MicroG enabled
BeaconDB enabled
Location enabled in settings. High accuracy enabled
edit:
pure maps and osm scout server from chum
1.open pure maps
2.waited 5-6 mins for gps location to lock
3. Blue spinner always spinning
EXPECTED RESULTS:
ACTUAL RESULTS:
ADDONS:
AAS Bluetooth Bridge: yes
Patchmanager: no
OpenRepos: yes
Chum: yes
Other: none specified
Home Encryption: enabled
gps logs collected as defined by the docs available. will attach with a link as cant seem to find attach button
the initial version of this bug report was created using Bugger 0.9.18+git1
Test with gpsinfo program . Outside
See if you get any satellites .
If GPS has had no fix foreewer it takes loong time even outside to load all the data for the first fix. Should look like this.
Gps info can be found from jolla store
Yes, the first lock will take longer. if there is no beaconDB data in the area (you can wait or move to area with data to get the lock). If you (or someone else) collects and sends local data using Stumblefish, the lock will be almost instantaneous in the future.
