Go Applications Using Cgo
Has anyone got experience building go programs that rely on cgo? I’ve been trying with sb2 env GOARCH=arm GOOS=linux CGO_ENABLED=1 go build and I always run into the unrecognized command line option -marm on my system SDK. I confirmed that invoking gcc directly via sb2 is making arm binaries; usually that error is because it wants you to export CC but exporting CC=gcc makes no difference for me.
Are there any sources I could try with?
I was specifically having trouble building gio: https://gioui.org
Just curious if there was any progress on this?
I did build proton bridge, it resulted in a binary that produces Segmentation fault immediately, instead built on device directly (go is packaged in OpenRepos by me) and just created a rpm on my PC.
Ok. Cool. Ist that an independent app or library using cgo?
It’s an official open source bridge for using Proton Mail, it uses CGO to bind with libsecret.
