I’m using an Xperia 10 III running Sailfish 5.1.0.11. Since the update from the previous release, I have an extremely annoying issue with mobile connectivity in the Android support system.
I have searched the forum and not found any topic that was similar and not years old.
Device will have mobile data and the sailfish browser is able to resolve DNS and connect to servers. But every Android app will immediately claim to be offline. The only way to restore connectivity is to first restart mobile network through utilities. Then restart (regular?) network through utilities. After that, Android apps have data connectivity. This state lasts for minutes, sometimes 1, often 5-10 and sometimes up to an hour. But, inevitably, the Android layer goes offline again.
As the built-in browser is sadly out of date and also has no support for proper ad blocking, I almost exclusively use fennec for web. Also, the best apps for public transport are Android apps as well and obviously important when commuting for work. So the Android layer going offline every few minutes is a huge pain.
Two days ago I activated the “Treat mobile data as WLAN” option after having (to no obvious effect) tested deactivating it. Then, I had connectivity for more than a day and felt relief, but the next day the issue was present again.
It has gotten so bad that I’m using a secondary device for checking public transport and have the mobile hotspot enabled. This works flawlessly as native sailfish networking is fine. But it is a bit silly and cumbersome to dual-wield Xperia 10s (second device has HW damage and can’t connect beyond 2G any more).
I will set up a log collector for a few days and go over the system journal to try and determine what component is failing.
Is there anything obvious that I’m missing? Could I have changed some config file under /etc that might cause trouble? Can I supply some useful information for diagnostics?
