ohnonot wrote
There is no server.log anywhere in any of your apps’ directories.
YOUFISH_DEBUG=1 harbour-fintube
### start fintube, play 1 video, close it
library "libui_compat_layer.so" not found
library "libutils.so" not found
library "libcutils.so" not found
library "libhardware.so" not found
library "android.hardware.graphics.mapper@2.0.so" not found
library "android.hardware.graphics.mapper@2.1.so" not found
library "android.hardware.graphics.mapper@3.0.so" not found
library "android.hardware.graphics.mapper@4.0.so" not found
library "libc++.so" not found
library "libhidlbase.so" not found
library "libgralloctypes.so" not found
library "android.hardware.graphics.common@1.2.so" not found
library "libion.so" not found
library "libz.so" not found
library "libhidlmemory.so" not found
library "android.hidl.memory@1.0.so" not found
library "vendor.qti.qspmhal@1.0.so" not found
[D] unknown:0 - Got library name: "/usr/lib64/qt5/qml/io/thp/pyotherside/libpyothersideplugin.so"
library "libandroidicu.so" needed or dlopened by "/system/lib64/libmedia.so" is not accessible for the namespace "(default)"
[D] unknown:0 - [youfish] play(): building pipeline
video: "http://127.0.0.1:44355/play?u=https%3A%2F%2Fmanifest.googlevideo.com%2Fapi%2Fman"
audio: "http://127.0.0.1:44355/play?u=https%3A%2F%2Frr8---sn-qo5-9a4e.googlevideo.com%2F"
ua: "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWeb"
[D] unknown:0 - [youfish/hw] droideglsink created
[D] unknown:0 - [youfish] hw: uridecodebin stops at encoded video; droidvdec is explicit
[D] unknown:0 - [youfish] download buffering enabled (for seek)
[D] unknown:0 - [youfish] audio chain: eq= true boost= true limiter= true
[D] unknown:0 - [youfish] pipeline built, bus watch id 7
[D] unknown:0 - [youfish] source-setup on source
[D] unknown:0 - [youfish] set user-agent: "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWeb"
[D] unknown:0 - [youfish] set_state(PLAYING) returned ASYNC
[D] unknown:0 - [youfish] pipeline state NULL -> READY
[D] unknown:0 - [youfish] bus msg need-context from source
[D] unknown:0 - [youfish] bus msg stream-status from src
[D] unknown:0 - [youfish] bus msg element from source
[D] unknown:0 - [youfish] bus msg duration-changed from source
[D] unknown:0 - [youfish] bus msg element from hlsdemux0
[D] unknown:0 - [youfish] bus msg duration-changed from hlsdemux0
[D] unknown:0 - [youfish] bus msg need-context from souphttpsrc0
[D] unknown:0 - [youfish] bus msg have-context from souphttpsrc0
[D] unknown:0 - [youfish] bus msg stream-status from sink
[D] unknown:0 - [youfish] buffering 1 % (from downloadbuffer0 )
[D] unknown:0 - [youfish] buffering 3 % (from downloadbuffer0 )
[D] unknown:0 - [youfish] buffering 6 % (from downloadbuffer0 )
[D] unknown:0 - [youfish] buffering 12 % (from downloadbuffer0 )
[D] unknown:0 - [youfish] buffering 25 % (from downloadbuffer0 )
[D] unknown:0 - [youfish] buffering 50 % (from downloadbuffer0 )
[D] unknown:0 - [youfish] buffering 49 % (from downloadbuffer0 )
[D] unknown:0 - [youfish] bus msg element from souphttpsrc0
[D] unknown:0 - [youfish] bus msg stream-status from src_0
[D] unknown:0 - [youfish] video uridecodebin pad-added, isVideo= true
[D] unknown:0 - [youfish] linked video pad -> ok
[D] unknown:0 - [youfish] buffering 1 % (from multiqueue1 )
8< snip
[D] unknown:0 - [youfish] buffering 100 % (from multiqueue1 )
library "/apex/com.android.vndk.v30/lib64/hw/android.hidl.memory@1.0-impl.so" needed or dlopened by "/usr/libexec/droid-hybris/system/lib64/libvndksupport.so" is not accessible for the namespace "sphal"
[D] unknown:0 - [youfish] buffering 0 % (from downloadbuffer0 )
[D] unknown:0 - [youfish] buffering 100 % (from downloadbuffer0 )
[D] unknown:0 - [youfish/hw] video size QSizeF(1280, 720)
[D] unknown:0 - [youfish] bus msg tag from hwvsink
[D] unknown:0 - [youfish] bus msg latency from hwvsink
[D] unknown:0 - [youfish] audio uridecodebin pad-added, isAudio= true
[D] unknown:0 - [youfish] linked audio pad -> ok
[D] unknown:0 - [youfish] bus msg latency from asink
[D] unknown:0 - [youfish] bus msg tag from asink
[D] unknown:0 - [youfish] pipeline state READY -> PAUSED
[D] unknown:0 - [youfish] bus msg async-done from youfish-player
[D] unknown:0 - [youfish] bus msg new-clock from youfish-player
[D] unknown:0 - [youfish] pipeline state PAUSED -> PLAYING
[D] unknown:0 - [youfish/t] preroll (build->PLAYING) 1561 ms
[D] unknown:0 - [youfish] bus msg stream-status from asink
[D] unknown:0 - [youfish] bus msg qos from hwvsink
[D] unknown:0 - [youfish] bus msg qos from hwdec
[D] unknown:0 - [youfish] bus msg element from downloadbuffer0
The above log gives no hint about deno.
I manually downloaded a video with yt-dlp --verbose, it mentions both ejs and deno in a way that reads like it found them and will use them.
So that’s OK.
I am now thinking that your app does not see deno if it hasn’t installed it itself. But if yt-dlp is user-provided, it makes sense that deno could be user-provided too.
And what about yt_dlp_ejs? As I’m reading this both elements - EJS and js runtime - are required, but yt_dlp_ejs is not always included when one manually installs yt-dlp.
masen wrote
Ah that must be because it cant find the deno binary, i got a bit gaslighted by Claude it said everything was a 3rd party download from the settings menu.
But obviously (as i realize this in post) i downloaded Deno using the curl script from their official page
This one: curl -fsSL ``https://deno.land/install.sh`` | sh
The script seems to install deno to /home/defaultuser/.deno/bin/deno
Looking at the python script that looks for deno it says:
_DENO_CANDIDATES = (
os.path.expanduser(“~/.deno/bin/deno”), # default deno install location
os.path.expanduser(“~/.local/bin/deno”), # common user-local spot (a launcher’s PATH omits it)
“/usr/local/bin/deno”,
“/usr/bin/deno”,
So try to copy to that path and reinstall the provider or try the latest release (1.0.0-2) that should install deno bundled with the PO provider (aswell as that nightly release yt-dlp binary as an option)
My logs look like this, you can see the initial [youfish/t] pot_ensure which tells me that its serving tokens.
[youfish/t] pot_ensure 0.65s
[youfish/t] dump 4.48s rc=0
[youfish/t] resolve TOTAL 5.14s
video: “``http://127.0.0.1:35765/play?u=https%3A%2F%2Frr8---sn-c5ioiv45c-5gol.googlevideo.”
audio: “``http://127.0.0.1:35765/play?u=https%3A%2F%2Frr8---sn-c5ioiv45c-5gol.googlevideo.”
ua: “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWeb”
[D] unknown:0 - [youfish] set user-agent: “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWeb”
[D] unknown:0 - [youfish] pipeline state NULL → READY
[D] unknown:0 - [youfish] buffering 1 % (from downloadbuffer1 )
[D] unknown:0 - [youfish] buffering 3 % (from downloadbuffer1 )
[D] unknown:0 - [youfish] buffering 24 % (from downloadbuffer0 )
[D] unknown:0 - [youfish] buffering 0 % (from downloadbuffer1 )
[D] unknown:0 - [youfish] buffering 9 % (from downloadbuffer1 )
[D] unknown:0 - [youfish] buffering 21 % (from downloadbuffer1 )
library “libcom.android.media.swcodec.apexcodecs.so” not found
[D] unknown:0 - [youfish] linked video pad → ok
[D] unknown:0 - [youfish] buffering 7 % (from downloadbuffer1 )
[D] unknown:0 - [youfish] buffering 4 % (from downloadbuffer1 )
[D] unknown:0 - [youfish] buffering 100 % (from downloadbuffer1 )
[D] unknown:0 - [youfish] linked audio pad → ok
[D] unknown:0 - [youfish/hw] video size QSizeF(1920, 1080)
Note the: [D] unknown:0 - [youfish/hw] video size QSizeF(1920, 1080) Implying 1080p playback.
So i havent had the need for the EJS as far as i have seen?
EDIT: i understand now why i havent had the need for the EJS now, the binary that the apps download bundle a Python fallback thats why its been working without me being aware.
So i guess i have another thing on my checklist to fix, allowing yt-dlp to access deno very helpful report actually
Thanks!
ohnonot wrote
Thanks.
yt-dlp has access to deno, at least when I use it by itself.
I cannot get the string pot_ensure with YOUFISH_DEBUG=1 harbour-fintube.
There is still no server.log in your apps’ locations.
I hope your app allows yt-dlp access to deno in ~/.local/bin, even if the app itself cannot see it.
Since yt-dlp defaults to using deno anyhow, it just has to find it in PATH. I don’t think it looks in ~/.local/bin directly.
I guess the same would go for ffmpeg which I have now installed in ~/.local/bin as well (something I commonly do on my SfOS devices).
I’m attaching a verbose log from a video download with yt-dlp.
This shows you that it finds ffmpeg in PATH and supposed ly also deno but it still says “[debug] [youtube] [pot] PO Token Providers: none” in the beginning.
Long story short, I don’t know 100% if SfOS apps and their subprocesses generally have access to environment variables like PATH.
This dialog should really be public so more eyes can look at it. If you want I can ask a mod to do that.
Here’s the log:
yt-dlp --verbose "https://www.youtube.com/watch?v=g1S7Fo-vjTA" >yt-dlp.log 2>&1
[debug] Command-line config: ['--verbose', 'https://www.youtube.com/watch?v=g1S7Fo-vjTA']
[debug] Encodings: locale UTF-8, fs utf-8, pref UTF-8, out utf-8 (No ANSI), error utf-8 (No ANSI), screen utf-8 (No ANSI)
[debug] yt-dlp version nightly@2026.08.25.233329 from yt-dlp/yt-dlp-nightly-builds [66f49765d] (pip)
[debug] Python 3.11.15 (CPython aarch64 64bit) - Linux-4.19.248-aarch64-with-glibc2.41 (OpenSSL 3.5.6 7 Apr 2026, glibc 2.41)
[debug] exe versions: ffmpeg 7.0.2-static (setts), ffprobe 7.0.2-static
[debug] Optional libraries: Cryptodome-3.23.0, brotli-1.2.0, certifi-2026.07.22, mutagen-1.48.1, requests-2.34.2, sqlite3-3.50.4, urllib3-2.7.0, websockets-17.1, yt_dlp_ejs-0.8.0
[debug] JS runtimes: deno-2.9.5
[debug] Proxy map: {}
[debug] Request Handlers: urllib, requests, websockets
[debug] Plugin directories: none
[debug] Loaded 1745 extractors
[debug] [youtube] [pot] PO Token Cache Providers: memory
[debug] [youtube] [pot] PO Token Cache Spec Providers: webpo
[debug] [youtube] [jsc] JS Challenge Providers: bun (unavailable), deno, node (unavailable), quickjs (unavailable)
[youtube] Extracting URL: https://www.youtube.com/watch?v=g1S7Fo-vjTA
[youtube] g1S7Fo-vjTA: Downloading webpage
[debug] [youtube] Forcing "main" player JS variant for player 6a0e84d6
original url = /s/player/6a0e84d6/player_es6.vflset/en_US/base.js
[youtube] g1S7Fo-vjTA: Downloading visionos player API JSON
[youtube] g1S7Fo-vjTA: Downloading m3u8 information
[debug] [youtube] g1S7Fo-vjTA: Detected experiment to bind GVS PO Token to video ID for web client
[youtube] g1S7Fo-vjTA: Downloading player 6a0e84d6-main
[youtube] [jsc:deno] Solving JS challenges using deno
[debug] [youtube] [jsc:deno] Using challenge solver lib script v0.8.0 (source: python package, variant: minified)
[debug] [youtube] [jsc:deno] Using challenge solver core script v0.8.0 (source: python package, variant: minified)
[debug] [youtube] [jsc:deno] Running deno: deno run --ext=js --no-code-cache --no-prompt --no-remote --no-lock --node-modules-dir=none --no-config --no-npm --cached-only -
[debug] [youtube] g1S7Fo-vjTA: Some web client https formats have been skipped as they are missing a URL. YouTube is forcing SABR streaming for this client. See https://github.com/yt-dlp/yt-dlp/issues/12482 for more details
[debug] Sort order given by extractor: quality, res, fps, hdr:12, source, vcodec, channels, acodec, lang, proto
[debug] Formats sorted by: hasvid, ie_pref, quality, res, fps, hdr:12(7), source, vcodec, channels, acodec, lang, proto, size, br, asr, vext, aext, hasaud, id
[debug] Default format spec: bestvideo*+bestaudio/best
[info] g1S7Fo-vjTA: Downloading 1 format(s): 299+251
[debug] Invoking http downloader on "https://rr1---sn-qo5-9a4e.googlevideo.com/videoplayback?expire=1787806090&ei=Km2PaofMDcTC0u8Py6nB6A0&ip=2001%3A14bb%3Ace%3A809%3A69af%3A9a84%3A4c1c%3A3bcc&id=o-ADOb9a5TJ6bXDmiXBPCBGZtmCiQGJ9PB037KJu7bbC8n&itag=299&source=youtube&requiressl=yes&xpc=EgVo2aDSNQ%3D%3D&cps=150&met=1787784490%2C&mh=Xe&mm=31%2C29&mn=sn-qo5-9a4e%2Csn-ixh7yn7e&ms=au%2Crdu&mv=m&mvi=1&pl=49&rms=au%2Cau&initcwndbps=2801250&bui=AR3QkAk_FQg4O2Br1PHM25KAeYT9-Pum74dlFYCSdeCl7Ygkyr5aVTq0zVyWGh2XwDFzpUPRnFgdobXQ&spc=KBGBcim7xspuvTgKeUG7c_309rSsnSR9vHspQTYPmMZ7OATKyDgiJpJY_A&vprv=1&svpuc=1&mime=video%2Fmp4&rqh=1&gir=yes&clen=123489467&dur=252.920&lmt=1746366293571170&mt=1787784061&fvip=1&keepalive=yes&fexp=51565116%2C52135441&c=VISIONOS&txp=8208224&sparams=expire%2Cei%2Cip%2Cid%2Citag%2Csource%2Crequiressl%2Cxpc%2Cbui%2Cspc%2Cvprv%2Csvpuc%2Cmime%2Crqh%2Cgir%2Cclen%2Cdur%2Clmt&sig=AE0s2JYwRAIgC1GEgu1yPHhusQqUCX1Fef8gwka4n3CJtSUyyYAKPkMCIFjxF4DAo7u9jIwkMVA1UHFfElMc3Vsnt8y-EMGj2mcj&lsparams=cps%2Cmet%2Cmh%2Cmm%2Cmn%2Cms%2Cmv%2Cmvi%2Cpl%2Crms%2Cinitcwndbps&lsig=APaTxxMwRAIgGOtlza3Qn_PW42lAp1Ek-wNnWRQhRs-ZTyS9IASdIRICIH-MU5t79zPh6OSTVZnvSDfZZaicrsIYGhB46QWbJor5"
[download] Destination: How to enter the Boot Menu on a Toshiba Portege laptop - The easy way! [g1S7Fo-vjTA].f299.mp4
[download] 0.0% of 117.77MiB at 524.09KiB/s ETA 03:50
[download] 100.0% of 117.77MiB at 3.57MiB/s ETA 00:00
[download] 100% of 117.77MiB in 00:00:47 at 2.49MiB/s
[debug] Invoking http downloader on "https://rr1---sn-qo5-9a4e.googlevideo.com/videoplayback?expire=1787806090&ei=Km2PaofMDcTC0u8Py6nB6A0&ip=2001%3A14bb%3Ace%3A809%3A69af%3A9a84%3A4c1c%3A3bcc&id=o-ADOb9a5TJ6bXDmiXBPCBGZtmCiQGJ9PB037KJu7bbC8n&itag=251&source=youtube&requiressl=yes&xpc=EgVo2aDSNQ%3D%3D&cps=150&met=1787784490%2C&mh=Xe&mm=31%2C29&mn=sn-qo5-9a4e%2Csn-ixh7yn7e&ms=au%2Crdu&mv=m&mvi=1&pl=49&rms=au%2Cau&initcwndbps=2801250&bui=AR3QkAk_FQg4O2Br1PHM25KAeYT9-Pum74dlFYCSdeCl7Ygkyr5aVTq0zVyWGh2XwDFzpUPRnFgdobXQ&spc=KBGBcim7xspuvTgKeUG7c_309rSsnSR9vHspQTYPmMZ7OATKyDgiJpJY_A&vprv=1&svpuc=1&mime=audio%2Fwebm&rqh=1&gir=yes&clen=3865994&dur=252.941&lmt=1626272407796627&mt=1787784061&fvip=1&keepalive=yes&fexp=51565116%2C52135441&c=VISIONOS&txp=5311222&sparams=expire%2Cei%2Cip%2Cid%2Citag%2Csource%2Crequiressl%2Cxpc%2Cbui%2Cspc%2Cvprv%2Csvpuc%2Cmime%2Crqh%2Cgir%2Cclen%2Cdur%2Clmt&sig=AE0s2JYwRQIgDA_YyKstLg9JMdmb6PemSSnlkP6JOcb7lGY-Td_7UoYCIQCRTP5WJAFtPK1bSr4-lHVc0N-sItWUckqNRtxeBALzpQ%3D%3D&lsparams=cps%2Cmet%2Cmh%2Cmm%2Cmn%2Cms%2Cmv%2Cmvi%2Cpl%2Crms%2Cinitcwndbps&lsig=APaTxxMwRAIgGOtlza3Qn_PW42lAp1Ek-wNnWRQhRs-ZTyS9IASdIRICIH-MU5t79zPh6OSTVZnvSDfZZaicrsIYGhB46QWbJor5"
[download] Destination: How to enter the Boot Menu on a Toshiba Portege laptop - The easy way! [g1S7Fo-vjTA].f251.webm
[download] 0.0% of 3.69MiB at 175.43KiB/s ETA 00:21
[download] 100.0% of 3.69MiB at 2.82MiB/s ETA 00:00
[download] 100% of 3.69MiB in 00:00:01 at 2.45MiB/s
[Merger] Merging formats into "How to enter the Boot Menu on a Toshiba Portege laptop - The easy way! [g1S7Fo-vjTA].mkv"
[debug] ffmpeg command line: ffmpeg -y -loglevel repeat+info -i 'file:How to enter the Boot Menu on a Toshiba Portege laptop - The easy way! [g1S7Fo-vjTA].f299.mp4' -i 'file:How to enter the Boot Menu on a Toshiba Portege laptop - The easy way! [g1S7Fo-vjTA].f251.webm' -c copy -map 0:v:0 -map 1:a:0 -movflags +faststart 'file:How to enter the Boot Menu on a Toshiba Portege laptop - The easy way! [g1S7Fo-vjTA].temp.mkv'
Deleting original file How to enter the Boot Menu on a Toshiba Portege laptop - The easy way! [g1S7Fo-vjTA].f251.webm (pass -k to keep)
Deleting original file How to enter the Boot Menu on a Toshiba Portege laptop - The easy way! [g1S7Fo-vjTA].f299.mp4 (pass -k to keep)
(the forum software does not let me upload plain text files)
masen wrote
It’s fine to make this public if you’d like
Youtube still offers some videos with the older style video type that doesnt need the PO token at all but to get access to the “vast wide world of videos” you most of the time need those tokens hehe
Two easy ways to fix this:
- Update to the build that looks in the
~/.local/bin dir, i fixed that in the latest release.
or
- Symlink:
ln -s ~/.local/bin/deno ~/.deno/bin/deno every version checks ~/.deno/bin
You may have to press the “Reinstall provider” button
To explain the PATH thing, yt-dlp --verbose showing PO Token Providers: none is expected as that is the standalone binary in your path that doesnt have the bgutil plugin.
The app installs that plugin separately only when the provider is set up.
I have the fix for the deno EJS lookup queued for tomorrow (late night here atm), happy that you like it outside of this little hiccup
