BUILD ID = OS VERSION (Settings > About product): 4.X
HARDWARE (XA2, X10, X10 II, …): XA2, X10+
UI LANGUAGE: german
DESCRIPTION: console output is not properly displayed.
open fingerterm
produce some large output
turn display to change orientation (optional)
let the keyboard disappear
every output should be visible
some output is overwritten
i think you know this problem since a long time…
one of a few ongoing issues with Fingerterm, but I have noticed updates, so happy that it’s being worked on, and we also have Literm as a generally superior option, (but with a bit of an issue with cursor placement).
Anyone know of a way to make Literm the system default?
