REPRODUCIBILITY: Always
OS VERSION: 5.2
HARDWARE: Jolla Phone 2026
UI LANGUAGE: En
REGRESSION: Don’t know
Fingerprint unlock is limited to 5 fingerprints. I dont see a reason for such a low limit.
Go to Settings > Security > Device Lock
Add 5 fingerprints
Click “Add fingerprint” once more
You could add more fingerprints.
Error “There is not enough memory”
chr1s
19 September 2026 14:30
2
This is normal, even on Android phones. My last one could only store 3, and the one before that 4.
I assume it’s to avoid a big risk of incorrectly accepting the wrong prints, as the matches are not exact anyway.
This is a hardware limitation of the scanner chip. Different users of expensive phones have same result https://www.reddit.com/r/samsunggalaxy/comments/1kj6qhh/why_does_samsung_only_allow_3_fingerprints_to_be/
According to a 2019 tutorial below, you can cheat by: inputting a fingerprint, stop at 50%, and put another finger, so it registers a mix of two fingers within one slot.
