Why is the fingerprint sensor active while the device is in standby?
When I want to unlock the phone, I should be able to press the power button and then directly use the fingerprint sensor to unlock.
Currently, I have to release the power button after turning on the screen and then place my finger on the fingerprint sensor again to unlock the device. It is irrelevant whether I press the power button once or use the fingerprint sensor twice.
Disabling the fingerprint sensor while the device is in standby should also help save battery power.
Is this a bug, or is this behaviour intentional? Will it be changed in a future update?
I made a similar observation and would say it’s a feature. One explanation could be that it prevents the microswitch from wearing out too quickly. The downside, however, is that you may accidentally unlock your phone when you don’t want to—for example, while searching for something in your pocket. Or when taking your smartphone out of your pocket and placing it on a shelf. I’ve had a few situations where it ended up unlocked. Energy-wise, I bet this won’t consume any noticeable amount of battery power.
There are quite a few topics about this already, but I vaguely recall the original reason a single scan didn’t instantly unlock the device was that, on the first fingerprint-capable devices, the scanner only worked correctly when the screen was already turned on. So the workaround ended up being to require a double scan - the first one just turning on the screen or going to the lock screen, and the second actually checking whether the fingerprint matched anything in the database and unlocking.
The workaround still exists, but on the new phone, the scanner can already access the database even when the screen is turned off (you can tell because it only turns on the screen for known fingerprints), so it’s become pointless.
Can you put a link here? Did a short search before posting, but didn’t find something specific to JP2026. There might be different hardware requirements on various phones, but as jolla has full access on its hardware there should be more possibilities to do this correct.
Sure, and I can understand that you thought it could have been a problem specific to the new phone. Either way, I agree that the default behaviour should be changed.
This was the most recent one, actually also talking about the new phone:
This is one from a few years ago, on the Xperia 10 III:
Okay, first one actually seems to be the same topic, but the tittle is a misleading. So I missed it in my initial search.
I now tested with previously used Xperia 10II. Actually you are right, the same behavior there. Strange that I did not find this annoying all the years.
Still, pressing power button and unlocking in one go would be the correct and best behavior!
