Hello,
Not sure if I missed a configuration but I can only use the fingerprint to unlock the phone. However, it is not available in any App (android, sailfish, etc.) for authentication. Is there a solution?
Thank you in advance.
Hello,
It is not available on AAS side, but Sailfish apps can use it. For example it is possible to use it in BitSailor (native Bitwarden client)
Please search before posting.
On Android apps it’s not possible. On SailfishOS apps it’s simply not used much. As far as I know BitSailor and Containers are the only apps that actually use it.
