Hi,
after restarting my XA2, the phone no longer starts. No changes have been made recently.
In recovery mode, 4) Perform file system check
selected and get the following error message:
root: ***** FILE SYSTEM WAS MODIFIED *****
root: 43681/153600 files (0.3% non-contiguous), 456242/640000 blocks
Opening encrypted filesystem, you will be prompted for your security code.
Enter passphrase for /dev/sailfish/home:
e2fsck 1.45.4 (23-Sep-2019)
/dev/mapper/luks-home: recovering journal
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/mapper/luks-home: 153915/3063808 files (1.4% non-contiguous), 5541727/12235264 blocks
/dev/mmcblk0rpmb: read failed after 0 of 4096 at 0: Input/output error
0 logical volume(s) in volume group "sailfish" now active
Done
What options are there to restore the /home partition?
Thanks for ideas and solutions.
