BUILD ID = OS VERSION (Settings > About product): 4.1
HARDWARE (XA2, X10, X10 II, …): ALL
UI LANGUAGE: ALL
REGRESSION: (compared to previous public release: Yes, No, ?): YES
Since 4.1, it sems that ffmpeg-tools is no longer installed. In order to provide software that depended on ffmpeg, I was advised to just ‘use’ the local ffmpeg. However, I did not ‘Require’ it in my build. Now the software (Videoworks and Audioworks) no longer work. This is not such a Jolla problem with Videoworks, since it’s not in the store (yet). But Audioworks is in the Store and can no longer be supported for 4.1 / aarch64, since you’ve moved the goal posts.
3.4 → 4.1
- Install audioworks with version 4.1.
ffmpeg and ffprobe present in system.
not.
Well, since it’s not listed on your ‘supplied’ libraries/etc. pages, I probably can’t expect anything. But it is irritating since the suggestion to use Jolla supplied ffmpeg came from a jolla employee. This is really demotivating.
