What kind of clock adjustments are you talking about? Changing the time? I don’t know about SFOS 5.0, but in the previous versions that should be found in the Settings -> Time and Date. If you are talking about changing something the Clock app (timers and alarms), then there is a single setting to change the snooze duration under Settings -> Applications -> Clock, but you probably weren’t looking for that?
Or do you mean this?:
Alerts | OpenRepos.net — Community Repository System
That’s it, thanks a lot PasiK.At least previously it went to the Settings. Easy to adjust the volume of the alarm clock using this in the Settings. What about in 5.0, is this application still the only way to adjust alarm clock volume?
Try with direct storeman rpm, installer does not support beta releases and since this isn’t even a beta it’s not working as expected https://github.com/storeman-developers/harbour-storeman/releases/download/release1_sfos4.2%2F0.7.0/harbour-storeman-0.7.0-release1_sfos4.2.aarch64.rpm
Thank you. That did the trick and Storeman installed without hickup.
I also managed to install it. All, thanks a lot.
How did you manage to install Chum gui installer correctly? I was able to install it on C2 but it doesn’t show up on app list.
Edit: I managed to install Chum from its website by downloading the correct version and in termimal: pkcon install-local sailfishos-chum-gui-0.6.8-1.9.1.jolla.aarch64.rpm
Once Chum was up and running I forced it to load the repos from 4.6.0.15 in the Chum settings
same here. I charge it and keep it happy. love love the keyvoard. Though it is a little unweildy these days.
So I just got my C2 an hour ago.
First impressions - not good.
Upon opening box device was already on and running (!). Tried to setup but Wifi is not working (tapping on Connect does nothing). Decided to skip wifi setup and went through tutorial. When tutorial finished still couldn’t enable Wifi. It just says “WLAN is off” - Networking is not available. Please restart device.
And so i did - upon restarting it again booted into first run/setup screen - selecting language etc.
I can’t really update it since I can’t connect to internet…
Any ideas anyone?
It runs the startup wizard again as the previous attempt failed somehow. Did you continue to the end of the wizard? Note that there is no need to run the Tutorial again (escape at the top right corner).
Does Jolla plan to publish some technical documentation articles about C2? Something about recovery mode, OS reinstall (just in case), etc? Like for C1 and Aqua Fish
Also, does C2 have activation lock? Say, what will happen if a user forgets password and then reflashes the device? I saw in youtube video it was a problem with the original Jolla phone
Does the C2 have a sensor for Magnetic-Covers?
No, I have finished the setup the first time (along with the tutorial). Then went to settings and tried to enable Wifi. It said " Networking is not available. Please restart device." and so I did.
Upon reboot I was greeted with the setup screen again. Went again through it, this time skipping tutorial. The same thing, Wifi does not work - went to settings, still the same message.
At this point battery dropped from 20% when I opened the box to 3% and it said that phone will shut it self off. Just when I wanted to connect it to charger it shut off.
I had to go to work so I brought the phone with me, connected it to charger powered off. After an hour I powered it on, was asked to enter security code and after entering the loading spinner is shown and it’s stuck like this for almost 20 minutes now.
Don’t know what to do next
Like mine except for the battery. It was at 79 % and still going strong after leaving the phone on overnight.
So the startup wizard is marked as completed even though home encryption has failed - and we can’t remove one file. Of course this problem could hide an underlying hardware issue.
The safe bet would be to shut down the phone immediately if it wants to encrypt home again after a reboot and wait for a day or two for more information.
Succesfully downloaded and updated to 5.0.0.21.
So… No calls in or out with 4g, no internet acces for android apps from aurora i guess thats the main store for android apps, cant seem to find where to allow apps to get any kind of permission, i can see the permissions in the apps serting but i cannot give them, i these problems could be resovled i could actualy use this phone daily… Maybe.
Ooh and no sms in or out with 4g.
I had the same : the phone was running and just about 0% when I got it in my hands.
Welcome @Oine25 !
There was a mention earlier before phone launch that 4G VoLTE is a work in progress and will become available later. This might be the reason for not getting calls and messages out in 4G.
Please first try setting mobile connection to 3G.
3g takes calls and sms but no internet
