Favorite icon packs or themes for Sailfish OS in 2025?
Hey everyone,
I’ve been running Sailfish OS for a while now and I’m looking to give my phone a bit of a refresh — mainly in terms of visuals. It feels like most of the icon packs and themes I used to see recommended are either outdated or hard to find now.
For those of you still actively customizing your devices in 2025:
  • Which icon packs or themes are you using right now?
  • Are there any newer ones that still feel “native” to Sailfish’s style rather than Android ports?
  • Any tips for installing or tweaking them (especially for people who aren’t super into modding)?
Would love to see screenshots if anyone’s willing to share their setups — I’m curious how people are making Sailfish look modern without losing its unique feel.
Take a look at Theme Color. There are various theme, pack on OpenRepos/Storeman.
It’s relatively easy to manually edit ambiences beyond what the ambiences app does.
I also changed the default UI font.
I’m curious about the icon pack: how does the installation work? Does it have the same amount of icons/sizes as the default? Does it cover new apps?
this is my favorite icon pack. the original icons from meego on the Nokia n9
Those Harmattan icons are truly beautifull and timeless! :heart_eyes: Didn’t knew this existed for Sailfish. Just installed them. Does anyone have the original install files for the Evolve Plus icon theme? It was pulled from OpenRepos. :sleepy_face:
This package seems to be missing an rpm spec file, I have no idea how it installs what it installs.
Isn’t it possible to install manually from an rpm/any package?
Only problem is that the system isn’t aware, so, no uninstall, no updates…
But you can extract the content of it, at least do throw an eye on the icons.
(e.g. in a PC terminal with Midnight Commander, just hit enter on the rpm)
Atm, I can see that, it contains icons like this, and more
Another AI bot account.
https://laracasts.com/@harrycmary
”Hi, I’m Harry, a tech expert who loves writing about technology. I share simple and useful information about the latest gadgets, trends, and innovations to help everyone understand.”
https://www.youtube.com/@tech-harrycmary
Why do we entertain these clowns?
Why do you think you need spec file in rpm package?
There is no problem to use Remove in Storeman. If you are tinkering with rpm file you are on your own and uninstall manually.
Sure it is:
devel-su pkcon install-local foo.rpm
Just refrain from using rpm (the command) directly.
Olala, I have been unclear, sorry.
By “install manually”, I meant the next “manually” stage: extract, copy paste, rename. big bad tinkering.
Hence a mess with uninstall, update… (I guess)
Or something that explains what is being installed, how and where.
The way I see it, some original SFOS files must be overwritten for this to work. I’d like to know about the process.
Description clearly states that icons.
The details you can check in rpn package. It is not encrypted. I do not understand what is your problem or is there any at all?
