REPRODUCIBILITY:
OS VERSION:
HARDWARE:
UI LANGUAGE:
REGRESSION:
Open a music app and play your desired track
Plug in a USB to audio adapter
Connect an audio cable to audio in on HIFI/DAC/Headphones
Also install Audio Output from Storeman via CHUM repository
I expected the output to be from the HIFI/Headphones
No sound no matter which settings I choose from from speaker or Output to earpiece works.
I attached some screenshots also. I also tried to pair via Bluetooth to FiiO M15S DAC/DAP it connects once paired via Bluetooth and put the DAC into Bluetooth Receiving mode and connects via SBC codec, but no sound no matter if native music app or streaming and no matter which options I choose in the Audio Output either.
I tested with different audio cables and also with my Google Pixel 7 Pro with GrapheneOS and works fine either way.
