Fahrplan thread
I’ll have a look at it once I’ve:
a) implemented the movas api above,
b) looked at what’s wrong with 9292 (netherlands) …
thanks for the tip!
Ok, it’s a fast and dirty application of the patches :slight_smile: If you have a chance it’s in chum::testing
Show sailfishos:chum:testing / fahrplan - SailfishOS Open Build Service building as we speak …
@kfg thanks a bunch. Initial tests show it works fine. I’ll prepare a release on all channels. I noticed something slipped with the QML but that might have been a problem before (date time display, english).
If anyone has time to test, please let me know.
I can confirm, that it works well, thanks to @kfg and @poetaster
It works for me as well :slight_smile: great
Had a quick look at the commits on github. Everything applied correctly but I guess due to whitespace mismatches src/fahrplan_backend_manager.cpp.orig was created unnecessarily and slipped into the last commit.
Also tried out the aarch64 rpm from chum and as commented by the others it works like it should.
Yeah, one reject. Probably because I had made some tiny change :slight_smile: Nice patches …
Thank you very much!
EDIT: I’m pushing to chum proper and will deal with layout issues on Monday.
Are there layout issues in German?
For me it only working with option:
“Ausgewählte Fahrt”
Gesamter Fahrplan not working for a stop
The same stop under Parser vrr.de is working
  1. Deutsche Bahn
  1. Vrr
Which stop? Timetable or Journey view?
I’m not getting any timetable data with my usual from/to.
Timetable
not working
journey working
Ah the tram numbers are wrong
Strange
3 is line 4
Hmmm.
I’ll push that out tomorrow. Thanks!
Announcing version 2.0.47-2 with new DBahn backend and fixes for timetable view of same. Thanks to @kfg for the fixes. Sitting in Chum:testing and posted to openrepos.
I think you forgot to change version number. At least the one from Chum says 2.0.47-1
Many thanks to kfg and poetaster. Great work!
Will be there also a version for the official Jolla store?
Could be that the spec:
Version: 2.0.47
Release: 2
commit didn’t get tagged. looks like I did it out of order. I’ll just go do that again. Although, the 2.0.47 build on chum should still have the timetable fix in.
I have to ask someone at jolla about the repo in store. @rainemak who do I contact about the harbour repos. In the past i had asked @vige :slight_smile:
Strange: File _service:tar_git:harbour-fahrplan2.spec of Package fahrplan - SailfishOS Open Build Service
shows the correct foo. I’ll rebuild (testing) with my last tag. Though the spec is the same.
Ah, I think there is one extra place where the version is shown. And that is in the gui. I probably forgot to update that! EDIT, nope. Can’t be it either … hmmm
Thanks a lot for this update! I updated to new version on openrepos and am very glad to see information about journeys with Deutsche Bahn work again - althoug timetables still don’t work for me (on Xperia 10ii with Sailfish 4.6)
Many thanks! This is awesome :heart:
