That’s just the main one, you need the @harbour-fbjail one.
Oh, ok, sorry. That bit of text ran off the screen and I couldn’t see it. Flipped the phone to landscape and now I can.
Yes that should be running, stared automatically through the main booster service. Without it you see what you describe, app launched through GUI does not open.
Now to find out why it’s not running… No idea atm.
Anyway, if you start that service manually, the app should start normally.
Hmm, but other apps using webview (e.g. Tidings) work fine…
Ok, so I took a guess and replaced ‘status’ in your command with ‘restart’ and now the app does indeed open from the GUI. So I will see if it fails after time (couldn’t be that the booster got killed by OOM killer could it?). After all, the browser crashes almost daily here…
