Open Camera 1.51.1 on 4.5.0.19: all Settings sub-pages fail to render for some reason. Android back button still works, so app doesn’t completely hang.
sometimes when you rotate the screen, it updates the opencamera settings display. if you rotate it a few times, you can see where to click, even if you have to visually remember it when you rotate back.
OR you can edit the prefs and uri grants in the terminal.
i edit opencamera prefs to use camera2 and set save location to sdcard with a script that works something like this:
get root
calculate SAF URI of the folder and sdcard uuid you want to use
