External storage / Jolla C2 community phone
Ahoy, Good day to every SailfishOS user,
I just cannot find information on the maximum size of the micro sdxc card that the new Jolla C2 community phone. Can you help me in this issue?
Thank you for your help.
Eve
There is none besides filesystem one. Which is huuuge.
Right. I use a 256 GB card on the C2.
512 GB here - and no problems.
Thank you for all the replies. Using a 512 Sandisk Extreme pro. Works well. Yes, I can confirm that it can work with a 1TB as well.
