Some time ago I tried to install predictive text input and exchange support on my device. It didn’t work. I contacted Jolla Support and sent some logs/debug information. They told me, that the repos vanished from my device and adviced me to reinstall SFOS.
I’m not yet willed to go that path. There should be a way to add those repos again, shouldn’t it?
Can someone with those apps installed kindly show me the output of running the command
prompts for a Username and Password for the sailfish-eas and xt9 repos which I can’t provide obviously. I also tried to reboot the phone.
I will now Update to 4.5.0.19 hoping that this might automagically fix the repos now, but I doubt it to be honest. Probably this has something to do with my account or license not being “connected” to the repos and thus Jolla can’t verify, that I have a valid license and denies the access to the repos. That’s probably why they advised me to reinstall SFOS in the first place.
If someone knows how to add my license or account to the repos, I could still skip that reinstallation…
Tried that, yes, but it didn’t work. I tried to install from Jolla store and it still didn’t work.
However, I rebooted a second time (don’t know if that was part of the solution) and installed the packages from terminal. Now predictive text input and exchange works.
Exchange support is marked installed in store as well, but predictive text isn’t marked as installed.
The ssu lr output looks wrong. The xt9 and eas repos should be under the global section, not user.
Yes, I know. I also thought that this might be the problem. However, Somehow it healed itself.
Concerning the .ini Files under /usr/share/ssu/features.d/:
I have alien.ini and customer-jolla.ini, the other two are missing. Is there a way to recreate them?
