Are there any plans to enable dark theme on this site? It seems that the Discourse-platform should have dark theme bundled in by default.
Second this please, my eyes are burning
I would prefere ambience colors and background. But also dark would be an improvement.
Please let it also be automatic, like other sites!
Badly needed. On Firefox I can force dark theme, but on the crappy SFOS browser, not so easily.
Michael Use Webcat, Iām sure it has a dark mode built into it; itās also a better browser overall.
I think these are the instructions?
I canāt fint it under my settings, someone was able to?
First: this setting is meant for site administration purpose/decision, not for the user to activate afaiu.
Second: SFOS does not have a ādark modeā.
And, yes WebCat has a dark mode and https://try.discourse.org works for WebCat as well as Fennec/Firefox in dark mode.
(whereas in case of WebCat you also need the QtWebKit libraries of leszek from his openrepos repository!
You can set your browser to display every site ādarkā you can type as url about:config then search for color and make settings similar like these
browser_display_document_use should be set to 2 (always on)
or if you use Firefox from android you can download the dark reader extension and set the contrast to maximum
But is this working automatically with 4.5.0.16 now for the forum?
I forgot where I read that, but some modifications are needed to provide a dark mode.
Go to settings/apps/browser/settings and choose preferred colour scheme at the bottom.
Bear in mind the dark mode should be supported by tge visiting site too
Anyone know what a Dark Mode Ambience would need to support this in the browser and in webcat? My Ambience has āācolorSchemeā: ālightondarkāā but dark mode doesnāt work automatically on that discourse website.
you can go into about:config in the browser, then search for color and then make settings like these in the screenshot
the browser.display.document_color_use=2 is essential to activate your color settings
Sure, for a user that is a good setting.
But for a developer, if you want to offer the automatic dark mode. How do you set that in an Ambience?
Maybe it is possible to edit the settings files directly?
