E-Mail: Double-tap zoom not working
REPRODUCIBILITY: 100 %
OS VERSION: 5.0.0.67
HARDWARE: Xperia 10 II
UI LANGUAGE: German
REGRESSION: Yes
Starting with SFOS 5.0.0 the double-tap to zoom feature is not working in the native e-mail application anymore.
An e-mail account was set up.
  1. Open the native mail app
  2. Open any e-mail
  3. Douple-tab and try to zoom by moving your thumb up or down
The e-mail content is zooming in/out.
Nothing happens, the zoom is not working.
None.
I have older system (4.5.0.25), but fresh flashed onto device a week ago, and made also strange observations.
After opening an e-mail it appears in tiny letters the whole mail compressed into the tiny screen.
scrolling is not possible.
Magnifying the image by Two finger gesture enables the new one finger up down zoom fearure.
This feature heavily malfunctions (on my device):
It magnifies also the top header bar until it covers most parts of the screen or the whole screen. Therefore, mail text is unreadable.
Also automatic line break is not working.
Double tab disables the new zoom gesture and mail is again displayed as written above.
Mail app is in unusable state at the moment.
I’m sure there’s a bug especially in the latest mail app version because all other things on the phone working fine.
Any tweak possible to disable the new finger - zoom feature for testing?
This sounds like the old web view issue. I once had that and there was a solution by deleting a specific folder. I could try to find the topic tomorrow
You are then by definition not on the latest version.
Yes, absolutely correct.
To be always on the latest version I would have to destroy a laboriously at the end working fine OS and import Jolla’s latest bugs. On my daily phone, I really don’t want to do this! It confirms the old wisdom: Never touch a working system. (For experiments I have another phones.)
edit: No idea what I can do to fix it. I give up. Sorry, now installed K-9 Mail and worked after 5 minutes of installation and config time. Have e-mail on the phone again.
Maybe I’ll try to troubleshoot on this issue later on my tinkerphone.
