DoesNemo.Configuration 1.0 ConfigurationGroup {}
actually save to .config/dconf/user ? I just stumbled over something (updating imports) and thought, eh, where does this serialize to?!
Yes, it does. If you run grep --text on it, you’ll find your stuff.
It does work, BUT some data types (unusual ones) will not map correctly or not at all.
See the source code for such corner cases.
Also I find sometimes you have to use the get and set methods (value(…), getValue(…)) rather than plain QML properties and bindings to get reliable results.
I was just wondering how that all fits together with the sailjail model. It’s a single file shared by any app that uses Nemo.Configuration.
Sigh. I tried dconf dump /apps/app.qml/musicex/ as an example but that doesn’t work. Neither does read. But the values are in the user dconf file. hmmm.
IIRC they get stored correctly, but converted wrongly on retrieval.
I gave up on using it.
I tend to steer away from configuration backends since I prefer using sql(lite) but it’s very handy to have a declarative mechanism … I wish it had a plug-able backend :slight_smile: But, I suppose it’s just time to write my own qml types that uses sql as a backend. Maybe someone has?
Right tool for the job thing I guess.
For simple stuff, like storing some setting/config bools or ints it’s perfectly fine and simple to use.
As a generic storage backend for ‘random’ data not so much.
And it’s insecure - AFAICS any app that can guess the right paths can access any other apps values.
