What can the Counter application do with access to the camera and microphone ? And Location ?
are you new to sailfish ?
i thought not
if an application seems to require all the rights, it means that the developer did not update the app since ages and the app therefore does not define which rights it exactly needs (so at least 2+ years)
just check the last update of the app
or visit the repo and check the code if available
Yes, I am new in this “question” :-). I just installed the application (yesterday / today).
Good question, because reading the reactions in store this is still a bit unclear …
Taken from the blog on this topic: “Our intention is that when we turn the sandboxing on for all apps, the current existing apps will not be broken. Therefore the default profile will have broad enough permissions to allow any previously Harbour-allowed app to function.”
This is also handled in the comments for said app in Harbour. (The ones still visible, not behind a further interaction).
You don’t need to worry, it’s no problem and doesn’t harm anything. If you grant the access, it will work.
