Docker engine on SailfishOS?
Hi,
Is it possible to install and run the Docker engine on SailfishOS?
I wanted to experiment a bit in running micro-ROS agents in a Docker on the phone and for that I tried to install the Docker engine on my phone (JP26, 5.2.0.17). I have followed more or less the configuration shown on Docker on Sailfish OS · GitHub. However, quite soon I have seen that I could not run the container as the mqueue device was not available. I could confirm that the kernel configuration CONFIG_POSIX_MQUEUE is missing.
Is there a known way to get it working?
Thanks
Some of the kernel configs required for docker / containerd / etc., are probably missing on most devices, and there is probably no way around that. We might add those config options in the future in the default kernel config requirements, as they are indeed nice to have.
Thank you @Keto for your quick reply. I am happy to hear that it could be supported in the future!
