Currently, when both Wi-Fi and mobile data (4G/5G) are turned on, it is not immediately clear from the top status bar which connection is actively being used for data traffic.
It would be a great usability improvement if the active connection icon (either the Wi-Fi symbol or the mobile network/4G indicator) were highlighted with a distinct color (e.g., the primary ambience color) while the inactive/standby one remained dimmed or white. This would provide instant visual feedback at a glance without needing to pull down the Top Menu.
This may happen when mobile data is enabled too and when the Wi-Fi connection is not working. You usually see both icons, switching one after the other.
Which is why I resort to the ‘suckage’ scale instead of the binary. In my case, I generally have internet. Which antenna and which device currently sucks least is the object of some study in my day to day.
A. when wi-fi gets disconnected → it’s exactly the switch to turn on/of mobile data
B. when wi-fi is still connected, but for some reason doesn’t reach the internet → that would be fishy to say the least, ad you could have mobile data off and still kicking in on wi-fi failures and then disconnect after the faulty wi-fi actually disconnects (fallback to mobile data switch’s decision) – none of this actually makes any sense.
