I started this conversation month ago at the sailfish-devel mailingslist. Now, lets continue here.
With newer Sailfish OS version (starting from 3.3.0.16) I noticed a regular drop of an established TCP connection during device sleep in the Shmoose xmpp client [1]. I was able to prevent his by triggering the iphbd regularly in the previous versions. This seems not to work as expected anymore.
The only way to get a stable long-term TCP connection with the current SFOS releases is by using this on the command line:
mcetool -searly
This disables late suspend of the device. Battery drain is only slightly more at my device with this setting.
Two questions on this:
Has this changed from the previous SFOS versions? I did not need this for Shmoose in the past.
Can this setting be applied to SFOS programmatically within an app with no special permissions? How would one do this?
Seems like Whisperfish [1] has the same issues.
Is the source of mcetool available somewhere so we can have a look what this tool does in the SFOS system?
Thank your for this!
After reading the code one can see that it uses D-Bus communication to configure the required suspend mode. I will try if this can also be triggered from within apps.
I am playing with an API requester that is pulling in some data regularly and I noticed that its complete suspended when the device is locked and not plugged to the power supply. @geobra did you found a solution yourself for your scenario? I also wonder what essentials services/processes do to keep alive (any proc priority config)?.
