Hi,
I am currently trying to port my apps to 64bit. I managed to connect to my Sony 10 II via Qt Creator. When I test the connection I get an okay.
But when I try to deploy my app I geht a permission denied error:
Usage: dbus-send [--help] [--system | --session | --bus=ADDRESS | --peer=ADDRESS] [--
dest=NAME] [--type=TYPE] [--print-reply[=literal]] [--reply-timeout=MSEC] <destination object path>
<message name> [contents ...]
Permission denied, please try again.
defaultuser@xxxxxxxx: Permission denied (publickey,password).
rsync: connection unexpectedly closed (0 bytes received so far) [sender]
rsync error: unexplained error (code 255) at io.c(226) [sender=3.1.3]
I am very positive that i used the correct password. The password is asked for every time I try to deploy but only once. Using SSH I can access the phone. Qt can launch a terminal as well.
What did I miss that I am not able to deploy my app?
