Delayed mobile data connection after flight mode
OSVERSION: 4.6.0.15
HARDWARE: Sony Xperia 10 II - Dual SIM - xqau52 - xqau52 - 1.0.0.16 - aarch64
UI LANGUAGE: Suomi (user: fi_FI, os: fi_FI.utf8)
REGRESSION: not specified
It takes up to 45 seconds to connect mobile data after turning off the flight mode.
  1. Ensure mobile data is on
  2. Turn flight mode on and wait e.g. 10 seconds
  3. Turn flight mode off
EXPECTED RESULTS:
The mobile data 4G is restored almost instantly.
ACTUAL RESULTS:
It will take up to 45 seconds to restore the mobile data.
  • Patchmanager: no
  • OpenRepos: no
  • Chum: yes
  • Other: none specified
Home Encryption: enabled
SIM provider Elisa
the initial version of this bug report was created using Bugger 0.9.10+git7
For some reason I had both sim slots active though having only one sim card installed. When disabling sim2, I could reduce network start time to 30 second.
This is normal. It never went faster.
I compared to Sony Xperia 10 II running Android. Android manages to get network on in about 5 seconds.
I am also having network lags when starting Android apps and started to think if the starting delay might affect on that feature too.
This is a very unpleasant but unfortunately normal feature of SFOS. I tested right now and switched to flight mode and back after 15 seconds, then it needs 1min 10sec to find the mobile network again. Very long, but this was always this way since I have SFOS (5 yrs).
edit:
also having network lags when starting Android apps…
This is also an old issue and as i now read from you, not fixed in latest version.
workaround: let aas run, close Android app that finds no network, restart network by Sailfish Utilities, restart Android app. Works mostly for me.
