I’d like to know if theres a way to add custom notification sounds to the operating system? The stock triplets for alerts and tones don’t work too well for my taste, they’re a bit more music than notification sounds.
So how can I add different/more sounds to the system? I’ve googled quite a bit, but found nothing. Even ready for download sound sets would be great. Is there anything like that?
You can select any of the music files on your phone as ringtone for the notifications.
Great, didn’t even think about it, although its quite obvious. Worked well!
With a bit of tinkering you can also put a “set” of sound files into /usr/share/sounds/foo/ and have them available in the Ambience editor directly.
Look at the directory jolla-ringtones on how that is done.
