i got an issue with my jolla phone2016, v5.0.2.22 related to the ringtone, i have only one sim in slot 1 but cannot set sound notification for it or messages, i can do it for sim 2 but as it’s empty the phone never rings
The question is, where in the forums can i ask for help on this?
I did not want to bug Jolla directly, was more a “support” section of the forum to get help from other users, since i did not find any and i’m pretty new i thought to leave it here.
I did try to swap the SIM to another slot prior to posting, but it did not play the ringtone either even while one was configure for that slot.
I tried it again after reading your post, when i changed the SIM from slot 1 to slot 2 it did not play any ringtone (even when slot 2 was configured to use one) or vibrate when receiving a call.
However, after placing it back in slot 1 i could change again the settings for that slot and it works properly now.
It’s strange because if the SIM was not seated properly then it should not receive calls either…
In any case it’s back to normal, not sure if the last update provoked this but i cannot reproduce it anymore.
