Custom launcher (shell script): How to close cover after completion?
It’s easy to add a custom launcher to your app menu, just drop a <something>.desktop file in ~/.local/share/applications that might look like this:
[Desktop Entry]
Type=Application
Name=Un/mount Server
Exec=/home/nemo/.local/bin/server-sshfs
Icon=/home/nemo/.local/share/icons/sshfs.png
This works as desired, but I’m getting a cover tile with a spinner that does not disappear after the script has completed, it just times out after a minute or so.
How can I avoid that?
I tried from within the .desktop file - all those commented options:
#X-Nemo-Application-Type=generic
#Custom-Launcher=yes
#X-Nemo-Single-Instance=no
#"StartupNotify=false
#[X-Sailjail]
#Sandboxing=Disabled
None made any difference.
Maybe there’s some command I can add to the shell script just before it exits?
Piggybacking on this, would this approach work for starting multiple apps at once?
I’ve been looking for a practical way to easily start all the apps I want running/open, especially after a reboot.
There’s an app called Takeoff which does just that.
Thanks! Did not know about it. It’s mostly what I wanted, however it doesn’t seem to work on Sailfish OS 4.4.0.58, on Xperia 10 II dual sim.
I see in the description from OpenRepos and GitHub that it doesn’t support yet versions of Sailfish OS 4.0.1.45 (Koli) and later.
I am guessing that a script with an icon could also solve the problem, but didn’t find the time to try it.
Thanks for the replies.
I have been looking around, also had a look at Takeoff (which basically just starts a systemd --user service - and the reason it doesn’t work is because lipstick.service doesn’t exist anymore), but nothing seems to adress my question.
I have the same problem, also I didn’t find a way yet to start root commands: devel-su command through a .desktop file.
qCommand can execute commands with root privileges.
It can also create a launcher for your script, but
a) it won’t work for devel-su commands and
b) it suffers the same limitations as described here.
I have this custom launcher .desktop file and cover disappears after the script is completed.
[Desktop Entry]
Type=Application
Terminal=true
Name=Scooter mode
Exec=sh “/home/nemo/.local/share/applications/runapps.sh”
Icon=icon-l-terminal
This didn’t work for me. The command wouldn’t run at all. It would work with:
sh -c “/path/to/script/script.sh”
But even then it keeps spinning until it hits a timeout.
By the way, I was able to run root commands with pkexec in my scripts instead of devel-su (it needs the security code of fingerprint for confirmation).
@Kuba77: your suggestion didn’t work for me either. Can you elaborate?
Curiously, Terminal=true also seems to do nothing.
I have been experimenting with running the script in a terminal; it isn’t perfect but acceptable. However, Fingerterm does not play well in this, I had to use ToeTerm, i.e.:
Exec=toeterm -e /path/to/script
@sailerx: thanks for the pkexec tip, that will come in handy evtl.!
