Crashing shortly after BUG: bsd rss-counter state
REPRODUCIBILITY: 50% (sometimes)
OSVERSION: 4.6.0.15
HARDWARE: Sony Xperia 10 II - Dual SIM - xqau52 - xqau52 - 1.0.0.16 - aarch64
UI LANGUAGE: Italiano (user: it_IT, os: it_IT.utf8)
REGRESSION: not specified
On sauna xperia 10 ii screen turns black. Leds stop blinking, no ssh, no reaction to button press.
dmesg tells (before crash)
255.790765] BUG: Bad rss-counter state m
m:ffffffc09cef6900 idx:4 val:45384
[13272.010609] i2c_geni 4a88000.i2c: i2c er
ror :-107
[13278.491027] i2c_geni 4a8c000.i2c: i2c er
ror :-107
[13278.613954] afe_get_cal_topology_id: [AF
E_TOPOLOGY_CAL] not initialized for this po
rt 45104
[13278.614129] afe_get_cal_topology_id: [AF
rt 45104
[13278.614254] send_afe_cal_type cal_block
not found!!
[13284.078311] afe_get_cal_topology_id: [AF
rt 45104
[13284.078467] afe_get_cal_topology_id: [AF
rt 45104
[13284.078535] send_afe_cal_type cal_block
not found!!
  1. See log
  2. Restart with power+volume key press
  3. Journalctl is empty
EXPECTED RESULTS:
ACTUAL RESULTS:
  • Patchmanager: yes
  • OpenRepos: yes
  • Chum: yes
  • Other: yes: appsupport.
Home Encryption: enabled
the initial version of this bug report was created using Bugger 0.9.10+git7
You could enable persistent logging. See instructions here:
Thank you! I successuflly catched one event.
The only notable event I find in the log is:
src/alien-radio-service.c:alien_radio_response_proc() slot1_alien getSignalStrengthResponse_1_2 ok
feb 10 12:57:26 Xperia10II-DualSIM ofonod[1264]: src/binder_netreg.c:binder_netreg_strength_cb() slot1 -77 dBm (57%)
feb 10 12:57:26 Xperia10II-DualSIM kernel: binder: 1264:1264 transaction failed 29189/-22, size 32-0 line 3096
feb 10 12:57:27 Xperia10II-DualSIM kernel: binder: 1264:1264 transaction failed 29189/-22, size 32-0 line 3096
feb 10 12:57:28 Xperia10II-DualSIM kernel: binder: 1264:1264 transaction failed 29189/-22, size 32-0 line 3096
