Couple few general impression with 1ii sailfish experience so far
1: it ships out with rarely minor bugs, nearly everything works perfectly without much modifications , even with 12g version.
2: aliendalvik works with some of dirty hacks, nearly 10iii experience, superb as always.
3: waydroid works as well with some minor modifications, da&waydroid can run in parallel, using kde connect to thread them together can get a extremely interesting experience. Power consumption doesnt see any impact when opening one or two contaners in parallel.
4: average power consumptions are arond 400-600ma when screen on and 150-300 when screen off. So after swapping the 5000mah battery can get a nearly full day usage(10 hours screen on time)
5: camera video recording works with some binary merges from android 13 blobs.
Currently only one thing not optimal is loudspeaker echo problem, but this happens when the opponent enables the loudspeaker but not my side, this is extremely hard to debug. Also the resolution are not pushed to full 4k, but im quite okay with it.
Also considering to recompile the boot partition a bit and see if i can get kernelsu and docker works, if those works this phone probably can last at least next 3-4 years.
Interesting read, any progress in the meantime?
everything except for 4k works now, pretty fantasic :laughing:
Sounds good, so (w)FullHD(+) FTW?
Yeah, sailfish run in 1096x2560 in most case, I found couple a few of settings can be changed without but didn’t have success yet, maybe some of them are helium related, need to touch the driver to make it stays at 4k, but probably not any priority since it uses way more battery than normal.
