thigg
8 February 2023 07:26
1
REPRODUCIBILITY: 0% (unknown)
OSVERSION: 4.5.0.16
HARDWARE: Sony Xperia 10 II - Dual SIM - xqau52 - xqau52 - 1.0.0.10 - aarch64
UI LANGUAGE: Deutsch (user: de_DE, os: de_DE.utf8)
REGRESSION: yes (since: 4.4)
Could not make calls after 4.5.0.16 update until full reboot (vol+pwr up for 10 secs)
Install 4.5.
Click any number in the phonebook
reboot normally
same behavior
force reboot with vol up + power for 10 seconds until 3 vibrations
6- works
EXPECTED RESULTS:
Calling ui opens even without force reboot
ACTUAL RESULTS:
Nothing happens, no error, just no reaction unti forced reboot.
(even reboot does not seem to work for @philter )
This is in the logs:
Feb 02 22:16:33 Xperia10II-DualSIM voicecall-ui[6299]: [W] unknown:0 - QString VoiceCallManager::defaultProviderId() const No provider added
Feb 02 22:16:33 Xperia10II-DualSIM voicecall-ui[6299]: [W] unknown:332 - file:///usr/share/voicecall-ui-jolla/VoiceCallManager.qml:332:5: QML VoiceCallManager: No provider found for modemPath: /ril_0
Feb 02 22:16:36 Xperia10II-DualSIM voicecall-ui[6299]: [W] unknown:0 - QString VoiceCallManager::defaultProviderId() const No provider added
Patchmanager: no
OpenRepos: yes
Chum: yes
Other: none specified
Home Encryption: enabled
Just to double check, so after the reboot the phone calls worked normally and you haven’t had issues to make calls?
thigg
8 February 2023 08:14
3
No, calls work fine right now.
I have the same problem.
Emergency call works in the dialog box before entering the security password.
SMS works.
The force reboot solution proposed NOT solved.
thigg
14 February 2023 18:53
5
Do you get the same logs?
Thank you, I not thinked to post it.
I checked journalctl right now: I confirm i receive the same log:
feb 15 07:04:30 Xperia10II-DualSIM voicecal
l-ui[13067]: [W] unknown:0 - QString VoiceC
ovider added
l-ui[13067]: [W] unknown:332 - file:///usr/
I launched the call from gdbus script on the shell, and also from browser link with same result.
I swapped sim to slot 2 and viceversa, and tried also a different sim.
Wifi works fine, and also mobile connection.
4g voice call is not selected.
I ran zypper dup that removed only rockpool, and ran sfos upgrade veify and pos upgrade.
thigg
15 February 2023 07:19
7
I assume you are sure, that you did the full reboot with holding vol up + power for a loong time?
Hello thigg, yes, I tried. Nothing solved until now
I ended up flashing again the Xperia 10 ii.
Now all works fine.
vige
6 March 2023 11:13
10
Thanks for the report, I added this to our internal bug tracker.
tomic
6 March 2023 19:22
11
