REPRODUCIBILITY:
OS VERSION: 4.5.0.24
HARDWARE: XPeria 1 II
UI LANGUAGE: US
REGRESSION:
wake_lock constantly being required by moded_usb, either with moded_usb_input or moded_usb_state. This greatly impacts the current required by the sleeping system.
- Install the os
- check with cat /sys/power/wake_lock when device is screen off
- cpu merely gets into sleep, power constantly remains at around 200ma
if this were used for handling usb event, does it better store the mode in the disk? At least don’t need to let it block the wake_lock all the time should be a better option.
P.S.: No matter it actives or not, when disabled, there will going to be a tftp_server showed in wake_lock, and both situation cpu does gets into sleep mode sporadically, so looks like it didn’t halt the sleep pattern, Is there any button I can close this bug?
