Connection to new wifi network requires restart of network stack
REPRODUCIBILITY: Always
OS VERSION: 5.0.0.43
HARDWARE: Jolla C2 Phone
UI LANGUAGE: English
REGRESSION: Connection to another or new wifi is not possible without modifications
After changing locating, the phone still shows it would be connected to the WIFI of the previously connected WIFI. As the WIFI in the current location is already know, it should auto connect to the available known WIFI.
Change of location, so that one gets out of range of a known wifi and reaches another known wifi.
see above
Automatically connecting to a known network and disconnecting when out of range.
Phone still shows being connected to a wifi network which is completely out of range at the current location. To connect to the wifi within range the following steps are needed:
  1. disable wifi
  2. restart network stack
  3. enable wifi
    (4. connect to new unknown wifi of device)
Duplicate of
OS update 5.0.0.55 (*) contains this fix:
“WLAN networks did not update properly without toggling WLAN off/on. Timeout for the scheduled scan was added.”
This fix probably eliminates the reported issue.
(*) Available for the Early Access subscribers currently.
