How can I have sfsdk use the Docker build engine of a remote machine?
You can’t. Well, I suppose it could be theoretically done by having a docker container ,running on the local host, forwarding the ssh port to the remote container. But we definitely do not support such a setup.
How is it sending commands to the engine? TCP only?
nmap on the host with the engine running gives me these ports as open:
PORT STATE SERVICE
22/tcp open ssh
2222/tcp open EtherNetIP-1
7777/tcp open cbt
