Compile rbw on Sailfish OS
I’m trying on my phone, I compiled rbw on my Xperia 10 III. I’m getting an error with pinentry.
[defaultuser@Xperia10III ~]$ rbw login
rbw login: failed to read password from pinentry: pinentry error: unknown command
I don’t have enough knowledge to make it work properly.
just out of curiouslty, could you post the output from
rbw config show
making sure to occlude personal data?
[defaultuser@Xperia10III ~]$ rbw config show
  "email": "xxx@xxx.eu",
  "sso_id": null,
  "base_url": "https://vaultwarden.xxx.eu",
  "identity_url": null,
  "ui_url": null,
  "notifications_url": null,
  "lock_timeout": 3600,
  "sync_interval": 3600,
  "pinentry": "pinentry",
  "client_cert_path": null
From the rbw-repo under “Configuration” it mentions
pinentry: The pinentry executable to use. Defaults to pinentry.
so I assume you have to install pinentry or something else compatible with it.
On GnuPG - Download it says following about Pinentry:
Pinentry is a collection of passphrase entry dialogs which is required for almost all usages of GnuPG.
I am getting the error message below.
However, I do have a popup on Sailfish.
The error is displayed immediately after the rbw login command; it does not wait for me to enter the password in the pop-up window.
Unsurprisingly the command pinentry is not available on SFOS. It can be installed from Openrepos/Storeman, or compiled as well I guess.
Any progress? Could you please share your spec file?
I know nothing about rbw, but the config suggests that they deliberately added choices for how to enter passwords. I’m sure a quick read of rbw documentation would reveal requirements & alternatives.
