Hi there,
very often when I write my apps it’s helpful, or rather, critical, to look at how others have chosen to implement a solution to a same problem. And for that I use GitHub very often, but not all apps are on GitHub (thankfully) and you need an account to perform the search.
Let’s make a long story short, I created a Hound instance dedicated to SailfishOS applications. Right now there are ~750 repos (many are forks). The full list is accessible from the advanced search panel.
I hope it will be of use to someone!
EDIT: I’ve added all missing Chum apps
