Clock application doesn't load {4.5.0.21}
REPRODUCIBILITY: sometimes
OS VERSION: 4.5.0.21
HARDWARE: i4113 Xperia 10
UI LANGUAGE: italian
REGRESSION:
Sometimes the clock app hangs on when tapped and tries to load only to crash.
Google services installed
  1. use the phone for sometime
  2. tap on clock app
  3. it will does that bug
The app is opened successfully
It hangs on. But sometimes it loads
Google services
Happens to me (XA2+) as well, here and then. It helps to restart home screen via Settings-Utilities .
On my XA2 (mono sim) it works fine. I’ll switch to X10 III soon I hope I don’t have too many problems… :frowning:
You mean the clock icon in the app grid (slide menu)?
I guess yes, you’re right. That’s it
can you collect logs when this is happening?
Made a new mobile phone with Xperia 10 III dual sim, everything ok. Works well.
