Chum Gui aarch 64 Tampella
Any news about install Chum on Tampella 5.0.0.55?
I get an error message after installation…on my 10v…
Install Chum not from Storeman but from its website (as for now…see direct link below). After successful installation, you should then change it manually for now to: 4.6.0.15 (Sauna) in the settings of Chum. At least this is what I’ve done to get the updates on my C2, assuming it works the same on the Xperia’s with SFOS 5. Please remember to his the „Enter” key to really enable this repository.
Here you go:
https://repo.sailfishos.org/obs/sailfishos:/chum/4.6_aarch64/aarch64/sailfishos-chum-gui-0.6.9-1.10.1.jolla.aarch64.rpm
hello thank you for the link and for a 32BITS version for my xa2 there is a version
Is that a question? If so, yes of course there is: https://repo.sailfishos.org/obs/sailfishos:/chum/4.6.0.15_armv7hl/armv7hl/sailfishos-chum-gui-0.6.9-1.10.1.jolla.armv7hl.rpm
It was. On the Storeman it didn’t work. A big thank you
Unable to delete ScummVm. I deleted the org.scumm directory but the app is still there
