REPRODUCIBILITY:
OS VERSION: 5.2.0.22
HARDWARE: Jolla Phone 2026
UI LANGUAGE: English
REGRESSION: Phone Charges to 100% when it shouldn’t
I have the battery charge threshold set to stop charging at 90% to preserve battery longevity. However the last few overnight charges, I have found the phone at 100% charge in the morning.
I have tried disabling and re-enabling the charge threshold setting but that made no difference.
Have a charge threshold set under battery aging protection.
Battery stops charging at the threshold set in the settings when the mode is activated.
I’ve been using the same charger since I got the phone, which originally came wirh a Xaiomi device and I think is Quick Charge 3 along with the proprietry protocol. I’ve been charging with the phone on. I’m not uisng any patches and the only thing I installed recently is Cargadgetd and Carfish which do use USB but I don’t think either modify system stuff, but I can try removing those and testing.
Yes, I suspected cargadgetd too. Charging tonight after having turned off its handshake service and restarting usb-moded, will report back in the morning.
Note that I had to press “Stop handshake” and run devel-su systemctl restart usb-moded before the “Ask Every Time” window would come back up and battery ageing protection would work again
I wasn’t able to resolve the issue, sadly parts of the protocol (well at least the open implementations I test against) may issue usb restarts in the middle of the session which with usbmoded would force you to unlock the phone and select cargadgetd, what’s even worse it would force me to restart it anyway as we need to present ourselves in a very specific way.
That being said - wireless cargadgetd is now a thing and that doesn’t stop usbmoded
Also I’ve added a massive warning that this will happen and added a small instruction that stopping the handshake restores usbmoded.
