When is 4G network available, the phone goes in 2G (maybe it is due part time wrong signal for seconds, but not going back in 3G or 4G) and stay there. Now it is for few days after newest update.
REPRODUCIBILITY: 100 %
OS VERSION: 4.5.0.21
HARDWARE: xperia xa2 plus
UI LANGUAGE: slovak
REGRESSION: by predecessor OS it happens sometimes, not so often
wrong network signal for some time
when the strenght of signal is enough for 3G or 4G, the phone changes the network for this level
No weak. The phone stay in 2G mode in area, where is 4G. It is the problem of sailfish os. Because when I change in the settings āmobile networkā 4G (itās set to this option) ā 3G and then from 3G ā 4G, the network change for 4G (data rate vie mobile network is faster again). But only for some time - then it changes to 2G and stay there
All this does is to tell the modem that - and you canāt seriously expect the OS to be changing this setting back and forth randomly/opportunistically.
Oj, you are in area where 4G is available. In your phone you have set preferred network 4G. But your phone remains in 2G. Do you think it is operator problem? No other people phones stay in 2G. It could be hardware problem with phone, but the phone can work in 4G (just change setting to 3G or 2G and then back to 4G and the phone works in correct network without problem till youāre in worse covered area). I think it is OS fault.
The setting defines the highest network level the phone connects to. If you prefer 4G, phone tries to establish 4G connection. If this fails for whatever reason, it tries 3G. If not possible for whatever reason, it tries 2G.
With setting it to 3G or 2G you can prevent the phone to connect to higher network level and so save power and battery time. You can choose a compromise between data speed and battery time before next charge.
No difference why 4G fails, because there is really no network available or establishing connection fails for other reasons like SFOS bug.
Now Iām abroad, roaming, Iām in house with lower signal. Out of house is 4G, inside 3G or 2G. But sometimes I lose signal and the phone doesnāt return to the network, it stays witout signal (in time Iām writing this post, the phone doesnāt have signal, but Iām sitting on sofa, where I have almost 3G before). The phone is set to prefer 4G, I try to change the settings, but without success. The only way is to reboot the phone to get the network.
Maybe Ofono Log -app would give you (or someone else in this forum) more information about what is happening with your modem/network. By default it logs ton of stuff, so hopefully someone could help you with the proper categories to filter unneeded stuff out?
I can confirm this problem, the phone sits on 2G but after restart it will happily establish 4G connection with full signal bar despite being in the same place. This goes on for some time until it drops to 2G again.
It seems to me (just by observing the behaviour, I havenāt analysed any logs etc.) that if 4G connection is not successful for some time after downgrade to 2G it stops trying.
(Side note: this is in Germany where carriers will do all kinds of weird stuff and connections are in general quite unreliable)
I wouldnāt consider German networks less reliable than the average mobile networks in other countries (except for Swisscom, maybe). Itās rather that Germans in general tend to feel like betrayed victims and are quite strong in whining but not in improving things:)
Well, itās of course anecdotal evidence, but Iāve used mobile networks all over Europe and nowhere have I hit so many weird behaviours as in Germany.
As an example, my everyday struggle, SIM1, foreign, roaming on Telekom, has full signal, SIM2, local, also Telekom meanwhile loses signal completely
I have also never before experienced so frequent downgrades to 2G, this is why Iāve hit the problem described in this thread in the first place.
Mh. Sounds rather like inconsistent Telekom network coverage resulting in the foreign sim roaming on other networks but the local sim switching to 2G. I also always had the impression that the network coverage abroad was better than in Germany - until I left touristical hotspots and experienced not only fringe but no coverage at all - e g. in Italy
Itās like the hospitals of neighboring cities which are always presumed to be better than your local ones:-)
Yeah, thatās a known IMHO separate issue for X10. Usually it takes half a minute on mine. Sometimes even longer. I donāt remember if I ever had to reboot for that reason.
I donāt have a solution or a tip as to what the problem could be, sorry.
My: Xperia 10 III/4G preferred/Operator 4ka/Slovakia.
Since my operator does not have full coverage, it uses Orange roaming. It hasnāt caused me any major problems so far. I confirm that sometimes it also happens to me that the GSM signal strength indicator and the data transmission protocol indicator completely drop out, I have no signal - 2G, 2.5G, 3G or 4G is not displayed. Then it wonāt help me to wait for the phoneās communication with the network to fix itself. I have to restart the device (soft restart of services in utilities does not help). Since it doesnāt happen to me often (max. 1-2 times a month), I learned to live with it. I donāt know if itās a fault on the side of the phone or the GSM operator. Switching from 4G to 3G, 2.5G and vice versa usually works fine for me without any problems.
I am german and feel a bit insulted by the comments, nevertheless when I was in a rather remote spot in Portugal I had perfect 4G coverage, even in a train to nowhere. Here in munich I struggle to send sms with Vodafone on 2G. I can confirm my XA2 degrading to 2G while 4G coverage is available. Almost constantly throughout the day, ofono restart helps sometimes, reboot more often. 4G worked fine on my old Xperia, though. I can provide logs or sth. if anybody has more insight on this topic.
There are simply areas where you CAN get 4G for an area of 2 square meters and move beyond that it drops. At my parents in law, If I go to the terrace, I can get 4G. If I move behind the house or INTO THE HOUS it drops to 2.5. If I go to one of the neighbors, and donāt move around a lot, I can get 4G without change. Until I move. Itās very flaky coverage there and all users (Iphones, android, me) on different providers have the same experience. Is it possible itās just this kind of āzoneā?
