I have a simple request. I need to change device lock using recovery mode.
I know the current one. I am just not able to type it as my screen is damaged and one digit is impossible to input. I want to change it to a code that can by typed.
I want to use the phone as is. Mainly for receiving calls and sms on my other sim. So I prefer solution with little to no investment.
does that work without any setup? I don’t want to buy a keyboard just to find out it doesnt work. But thank you for the idea. I am not sure Jolla 1 with SFOS 2 supports OTG.
I just tested, USB keyboards does unfortunately not work on the decryption lock screen, only on the later ones. And only on supported devixes, i.e. Xperias, ofc.
