Changed behaviour for APK installs, APK+ files not working?
I just reinstalled on an Xperia 10 III, normally I put over a collection of apks from an 10 III running android, open the files via file browser and hit ‘install’.
This time, all the normal apks just showed up as installed (they are in the app list), but half of the files were ‘apk+’ and have no install option at all, and cannot be run.
I can’t find anything about this in the forum, any ideas?
Use an Android installer: a store or a File Manager. X-plore File Manager and Total Commander are good.
I never sorted this out, and now I have a bunch of apps that are showing up as APK+ files, and can’t be installed/run.
If I try to use apkd-install, I get an error like this;
method return time=166270352.318500 sender=:1.254 ->destination=:1.356 serial=19 reply_serial=2
boolean false
In total commander the files look like this:
A ‘normal’ APK on top (base.apk) and an APK+ below (bitwarden). the APK+ files have no option to run or install.
Any tips welcome!
I never heard of apk+ file format. Have you tried renaming to apk?
I did and it didn’t work, but I found this just now which explains things…
Sadly my phone is now unbootable because of this shit…
Resolved!
The .apk+ extension that you are seeing in some Android app backups is a file extension used by the Helium Backup app. Helium Backup is a popular backup tool for Android devices that allows users to backup and restore their apps and data without requiring root access.
The .apk+ extension is used by Helium Backup to indicate that the APK file has been backed up along with its associated data. The plus sign (+) is used to differentiate these backup files from regular APK files.
When you use Helium Backup to create a backup of an app, it creates a backup file with the .apk+ extension that contains both the APK file and the app’s data. This allows you to restore the app along with its data, preserving your app settings, user data, and other app-specific information.
It’s worth noting that Helium Backup is not the only app that uses this file extension. Some other backup and restore apps may also use the .apk+ extension to indicate that a file contains both the APK and data for an app. However, the use of this file extension is not standardized across all backup tools, so it’s important to check the documentation of the backup tool you are using to understand how it stores and restores app data.
So you can rename apk+ to zip, extract base.apk from the zip and install as normal.
